TwinTurbo.NET: Nissan 300ZX forum - Detonation won't cause a code 34
ttsmokin
on October 21, 2014 at 9:31 PM
Usually if replacing or relocating the det sensor
posted by TriniTT
on October 21, 2014 at 04:50 PM
The ECU sets the code because of a problem with the sensor or wiring.
Update on code 34
ukrdon2006
11:04:21 10/21/14
Re: Update on code 34
ttz'in (NorCal)
11:32:39 10/21/14
Re: Re: Update on code 34
ukrdon2006
12:02:12 10/21/14
It's not impossible to trace, nor is searching
ThisIsSparTTa
12:16:06 10/21/14
Re: It's not impossible to trace, nor is searching
ukrdon2006
12:27:22 10/21/14
Re: Re: It's not impossible to trace, nor is searching
ttz'in (NorCal)
12:48:09 10/21/14
We can't hand-hold through the process
ThisIsSparTTa
14:26:51 10/21/14
The ultimate guide to ECU diagnostics (TT.net)
SammybTT(TN)
12:29:17 10/21/14
Re: The ultimate guide to ECU diagnostics (TT.net)
ukrdon2006
12:38:56 10/21/14
How many times have you cleared the codes ? (n/m)
ttz'in (NorCal)
12:59:26 10/21/14
Re: How many times have you cleared the codes ?
ukrdon2006
13:05:48 10/21/14
This page has the info you are looking for:
ttsmokin
13:52:21 10/21/14
if you relocated amd cleared codes...
Khronik
23:04:01 10/22/14
This is the first post I have seen from you and didn't
SammybTT(TN)
19:46:15 10/21/14
TriniTT
16:50:47 10/21/14
Detonation won't cause a code 34 -
ttsmokin
21:31:15 10/21/14
2nd
aliaZ
12:24:46 10/23/14
